Hi
I've been using XnView for a while with no problems but I've just installed it on a new computer and I'm not getting any 'go' or 'cancel' buttons on the Slide Show dialogue box. The dialogue box ends just below the 'Save' and 'CreateEXE/SCR' buttons. Which means, of course, that I can't run the slide show feature which is the main thing I want to use it for.
The computer is an OQO model 2 UMPC with a screen res. of 800x480, running winXP pro.
If I re-set the screen res. to the next higher figure (1000x600) it's fine. At the native res. the dialogue box fills the screen from top to bottom so it seems the program is truncating the box at the screen size. Is there a workaround for this that doesn't involve re-setting the screen res. every time I want to use it? I don't want to leave it at 1000x600 as, with a screen size of just 11x6.5 cm, any text is pretty hard to read..!
No 'Go' button on Slide Show dialogue
