A new nasty bug in 1.91.4
Dret
Post by Dret »
Hi
I'm reporting a new little, nasty bug...
During a moving file operations, while I'm dragging files from global folder to detinations ones, often the error message you can see below appear:
This nasty problem has a random solution: sometimes I have to restart the program to avoid it, sometimes I have to move before other files and then retry to move the previous ones.
Can you help me?
Thanks!
Bye!
Don't Panic!!!
Troken
Post by Troken »
I have encountered exact the same problem when moving files like that (drag). Have to open explorer to do it.
Troken wrote:I have encountered exact the same problem when moving files like that (drag). Have to open explorer to do it.
Strange, and do you reproduce it alwayls??
Troken
Post by Troken »
xnview wrote:Strange, and do you reproduce it alwayls??
As Dret mentioned, it is pretty random, I have not noticed any consistency. Some files just don't want to be dragged. I will make a better investigation next time it happens.
File with big size?
Troken
Post by Troken »
xnview wrote:File with big size?
I think they were around 300 kb and above.
