it would be nice if the location of geotagged images (images with GPS info) could be easily shown with Google Maps or Google Earth. Maybe via the context menu of the image or via a new toolbar button. For opening the location with Google Maps the initial zoom value should be set in the options.
It would also be very nice if geotagged images could be marked, maybe with a little "G" besides the "EXIF" marker.
Showing location of geotagged images
peterbonge
Regards,
Peter Bonge
Peter Bonge
Re: Showing location of geotagged images
Yes, will be great...peterbonge wrote:Hello,
peterbonge
Does that mean that there is a chance to see these features in one of the next versions? Do you also have an idea when this could be done?xnview wrote:Yes, will be great...
Regards,
Peter Bonge
Peter Bonge
Yes, if i found how to do that... Do you have a picture with GPS for me?peterbonge wrote:Does that mean that there is a chance to see these features in one of the next versions? Do you also have an idea when this could be done?xnview wrote:Yes, will be great...
peterbonge
Sure. To what address?xnview wrote:Yes, if i found how to do that... Do you have a picture with GPS for me?
Regards,
Peter Bonge
Peter Bonge
marsh
FAQ:How to contact the authorpeterbonge wrote:Sure. To what address?xnview wrote:Yes, if i found how to do that... Do you have a picture with GPS for me?
peterbonge
Thanks! The image is on its way.marsh wrote:FAQ:How to contact the author
Regards,
Peter Bonge
Peter Bonge
Currently nothingpeterbonge wrote:Thanks! The image is on its way.marsh wrote:FAQ:How to contact the author
peterbonge
Still nothing?xnview wrote:Currently nothingpeterbonge wrote:Thanks! The image is on its way.marsh wrote:FAQ:How to contact the author
Regards,
Peter Bonge
Peter Bonge
foxyshadis
He really has either the flakiest email server or a very aggressive spam-catcher. Perhaps the FAQ should update to say keep sending until you get a reply. :ppeterbonge wrote:Still nothing?xnview wrote:Currently nothingpeterbonge wrote: Thanks! The image is on its way.
Ok, i have itpeterbonge wrote:Still nothing?xnview wrote:Currently nothingpeterbonge wrote: Thanks! The image is on its way.
