Tagging menu
Sark
Tagging menu
Post by Sark »
Under the tag menu there are options for Tag, Untag and Invert. Next to Invert is a shortcut (Ctrl + T) which actually seems to be the Tag shortcut. Just wondered what exactly is Invert supposed to do?
Sark
foxyshadis
Post by foxyshadis »
Invert tags an untagged file or untags a tagged one. (Inverts the tag state.) Normally it's the only option you'd need, but things get more complex when you're applying it to lots of files.
Sark
Post by Sark »
I get it. Basically I can Tag and Untag (individual files) with Ctrl+T.
Thanks for the quick response
Sark
