HEllo,
if you select Install All Components in the XNView installer menu, the LUrawave 2000 plugin is not selected. You have to select it manually during the installation. Think this must be a bug
1.91.5: Installer: Lurawave 2000 plugin not selected
klumy
XNView 1.91.5
Windows XP SP3
Windows XP SP3
Re: 191.5: Installer: Lurawave 2000 plugin not selected
No, by default the Jasper JPEG2000 is installedklumy wrote:HEllo,
