TIFF CMYK with JPEG compression wrong display
wOxxOm
Post by wOxxOm »
TIF files saved in Photoshop may have JPEG compression which is very handy. However XnView displays such files wrongly in case it is CMYK TIF with JPEG compression.
Re: TIFF CMYK with JPEG compression wrong display
wOxxOm wrote: TIF files saved in Photoshop may have JPEG compression which is very handy. However XnView displays such files wrongly in case it is CMYK TIF with JPEG compression.
Do you have ties by enabling ICC?
wOxxOm
Post by wOxxOm »
usually it is not enabled, but enabling it specifically does not help, the thumbnail (after 'rebuild' command) and the image in viewer remain wrong.
p.s.
TIF RGB + JPEG compression are displayed correctly
TIF CMYK +JPEG cpr - wrong
TIF CMYK LZW - ok
TIF CMYK and RGB, ZIP - ok
wOxxOm wrote:usually it is not enabled, but enabling it specifically does not help, the thumbnail (after 'rebuild' command) and the image in viewer remain wrong.
p.s.
TIF CMYK LZW - ok
Could you send me it?
wOxxOm
Post by wOxxOm »
yes, I've just sent it to the address mentioned in the forum's howto.
