I'm using GFlax (love it!) and I have a multi page tif that shows up with the proper data in NumberOfImages, etc. However, I can't figure out how to load any page other than the first so that I can display it.
Is it possible to load any page other than the first in a multi page TIF?
Reading all images of Multi Page TIF
Re: Reading all images of Multi Page TIF
You can use the property Page = ??ahurley wrote:I'm using GFlax (love it!) and I have a multi page tif that shows up with the proper data in NumberOfImages, etc. However, I can't figure out how to load any page other than the first so that I can display it.
ahurley
According to the help file, Page is a read only parameter. In ASP I try to use the following
gFlaxObj.Page = 1
and I get a broken link. Remove that line, and it works fine but I only see the first image in the TIF.
I've also tried .NextPage with no luck as well as it also make a broken image.
Thoughts or suggestions?
gFlaxObj.Page = 1
ahurley
