Covert multiple Files though context menu
Neoras
Post by Neoras »
thanks for the teriffic Xn Viewer.
Here's a feature request that would give you at least one more commercial copy sold - mine :)
Like the topic says, I would like to convert multiple files through the context menu. Currently, when you select more than one file and choose "convert to...", only the first file will be converted.
I would appreciate an option like "convert multiple files" like STRG+U works in the viewer... even better with the dialog box being supressed.
Thanks and keep up the good work!
Neoras
Re: Covert multiple Files though context menu
Neoras wrote:Hello,
No, with the last version, XnShellEx must convert all selected files
Neoras
Post by Neoras »
Thanks for your quick reply, Pierre, but it still doesn't work for me.
I'm running Xnview 1.91.5 with XnViewShellExt.dll 1.6.0. When I select multiple JPG-Files in Windows Explorer and choose "Conver to [TIF]", Xnview spawns only one new file...
Thanks anyway :)
ckit
Post by ckit »
He's right, Pierre.
I just tried to convert 3 JPG's to BMP and only the first one was converted.
ckit wrote:He's right, Pierre.
Houps, i forgot to release the 1.6.1 :-)
http://download2.xnview.com/XnShellEx.exe
Neoras
Post by Neoras »
Excellent! It works perfectly now!
Thanks again - your great support is the reason why I threw Acdsee away and switched to Xnview instead :)
