Problem with .MOV files
paek
Post by paek »
hello,
my pc has windows 2000 prof. xnview 1.7.4 and quicktime 6.5.
if i play mov-datas in xnview, i get the following error:
*xnview.wxe has generated errors and will be closed by windows.
you will need to restart the programm.
An error log is being created.*
Re: Problem with .MOV files
paek wrote:if i play mov-datas in xnview, i get the following error:
Is it possible to have a sample, please?
paek
Hi Pierre !!
Post by paek »
i try to send you a sample..
thanks a lot.
see u later
panzerfaust
Quicktime MOV failures
Post by panzerfaust »
Having same sort of problems
WXP SP2
XnV 1.80.3
Attempting to play QT MOV files either:
1) causes runtime error and program crash (the "Do I Want to Send Err Rpt to MS" box)
2) Will play a few second of video - when the video image freezes (but the control shows progression).
If then Pause & restart, shows a single still frame - but from further in the clip. Pausing/unpausing eventually results in #1
Yes. These clips play fine in QT and, I must add, in IrfanView.
Re: Quicktime MOV failures
panzerfaust wrote:Having same sort of problems
WXP SP2
XnV 1.80.3
Which system do you have? Could you send me a sample?
Dreamer
Post by Dreamer »
WXP SP2
XnV 1.80.3
See above :wink:
I dont have problems with mov files, but I found another ugly bug - I'll start a new topic...
Dreamer
