Error when exiting the Options Window
PSHRutPark
Post by PSHRutPark »
After clicking through some of the options TABS I was unable to exit the Options window by clicking on "OK". Eventually had to use the "Cancel" button. I re-entered the options screen and when I clicked "OK" Xnview crashed.
Seems to happen after viewing a certain TAB. But haven't been able to repeat it.
Anyone else experienced this?
PETER
Win 2000 Pro
Perhaps options of 1.91.5 and 1.91.6 are not 100% compatible and cause the crash. Could you try renaming the option file (xnview.ini) and then retry editing the options?
PSHRutPark
helmut wrote:Perhaps options of 1.91.5 and 1.91.6 are not 100% compatible and cause the crash. Could you try renaming the option file (xnview.ini) and then retry editing the options?
Hasn't happened since ... although have tried to reproduce the error.
When the "OK" button wasn't reponding it simply would not do anything apart from "depress". Hence used the use of "Cancel".
The INI file has grown 200-300 bytes. New options?
PETER
Re: Error when exiting the Options Window
PSHRutPark wrote:After clicking through some of the options TABS I was unable to exit the Options window by clicking on "OK". Eventually had to use the "Cancel" button. I re-entered the options screen and when I clicked "OK" Xnview crashed.
You can reproduce it? Which option do you change?
Boum !
:arrow: Pierre
:) Hello !
…Which option do you change?
• For instance, THIS ONE HERE…:|
:mrgreen: KR
Re: Boum !
Clo wrote::
Ok, for “Use checkerboard for transparency” & 16bits display.
Is this bug resolved in 1.91.6 final?
