1.91.5: Status Bar info NOT updated navigating folder pane
The REAL Joe Blow
Post by The REAL Joe Blow »
When I change folders in the folder pane, the status bar always displays the number of objects found in the startup folder and free disk space, no matter what folder I navigate to, while the File List pane does update properly and display the files in the folder I navigated to.
When I navigate using only the File List (with 'Folders' and 'Parent Folder' turned on to allow navigation, then the Status Bar information properly updates to tell me at least the number of objects in the current directory.
It would be nice if the Status Bar updated like that when navigating with the folder pane.
ANOTHER MINOR STATUS BAR BUG:
It would also be nice if the Status Bar would tell you the size of all of the files in the directory - the way it is now it only tells me how may files there are unless I select them all, then it tells me the combined total file size, but I shouldn't have to do that 2nd step manually.
Many thanks,
The REAL Joe
Re: 1.91.5: Status Bar info NOT updated navigating folder pa
The REAL Joe Blow wrote:When I change folders in the folder pane, the status bar always displays the number of objects found in the startup folder and free disk space, no matter what folder I navigate to, while the File List pane does update properly and display the files in the folder I navigated to.
When i navigate with the tree view, the status bar is updated correctly, i can't confirm...
