Customizing Toolbar
parsec
Customizing Toolbar
Post by parsec »
Using 1.91.6 - it is quite easy to remove items from the toolbar in Options/Toolbar, but apparently impossible to add or move items. This can be done manually and tediously in the Application Data\XnView\default.bar file, but it seems there should be a way in Options/Toolbar to do it. Maybe I am missing something.
Thanks
oops66
Re: Customizing Toolbar
Post by oops66 »
parsec wrote:Using 1.91.6 - it is quite easy to remove items from the toolbar in Options/Toolbar, but apparently impossible to add or move items. This can be done manually and tediously in the Application Data\XnView\default.bar file, but it seems there should be a way in Options/Toolbar to do it. Maybe I am missing something.
Thanks
No it is already possible, you can use arrows to move the selected item, and "append" then "command"... to add news items !
( in toolbar in Options/Toolbar)
parsec
Post by parsec »
Thanks - I stand corrected. However, in my skin (Mezich) not all of the icons seem to be available (for example, "Print") which can be inserted manually.
oops66
Post by oops66 »
parsec wrote:Thanks - I stand corrected. However, in my skin (Mezich) not all of the icons seem to be available (for example, "Print") which can be inserted manually.
Yes, not all of the icons are available.
see here:
http://newsgroup.xnview.com/viewtopic.php?t=13670
It's there
:arrow: parsec
:) Hello !
• Do you mean in the main tool-bar, as I got it ?
- In that case, the “Print” icon is alright available in you skin,
it's located at position #12 on the bitmap (starting from left with "1").
- Maybe is it nice, but not very meaningful ? @ left below :
- @ right, one of mine, maybe more explicit…
- I don't remember whether it was set by default in all versions …
:mrgreen: KR
Small one
:arrow: oops66
:) Hello !
• The thread you link to is about the addition¦removal of icons in the small tool-bar of the browser…
… that indeed is not supported currently.
:mrgreen: KR
