store XnView.db outside "application data"
hmaarten
Post by hmaarten »
Hello
we have a domain with userprofiles stored on a central server, since we have a limmited space for each user i would like XnView to save its application data on an other location than the "\Documents and Settings\user\Application Data\XnView". especialy the XnView.db-file, because it grows verry fast!
thanks in advance!
Maarten
ckv
Post by ckv »
Go to Options -> Browser / Thumbnails / Cache tab and change the Use folder option to XnView or custom and in Options -> System integration you can change the location for rest of the files.
hmaarten
Post by hmaarten »
thanks!
that was easier then I expected
greetz
maarten
