- Thanks for a great piece of software
Adding keywords...use ENTER ?
jenscsj
When you write a keyword i the keyword field, you need to hit the "Add" button to add the keyword to the list. I think it would be a great improvement if you can add the keyword by pressing ENTER after you have written the keyword.
Re: Adding keywords...use ENTER ?
Yes, right!jenscsj wrote:When you write a keyword i the keyword field, you need to hit the "Add" button to add the keyword to the list. I think it would be a great improvement if you can add the keyword by pressing ENTER after you have written the keyword.
