Error Processing TIFF 1bit files with LZW compression
MarcoA
Post by MarcoA »
Hello everybody!
I'm using succesfully NCOVERT from version 4.78 for managing big tiff 1 bit files.
In particular the purpose is to decrease resolution from 2400 dpi to 150 dpi mantaining the the size.
As I wrote at beginning, everything works fine if I use TIFF 1 bit files with CCITT Group 4 compression.
As soon as I try to use TIFF 1 bit files using LZW compression, I got a system application error, and NCOVERT closes.
I downloaded and tried the version 4.83 but the result is the same.
The command is:
"NConvert.exe" -out tiff -c 2 -o "[FILEOUT]" -ratio -resize_bw_grey [width] [height] -dpi 150 "[FILE IN]"
Do you have any hint or particular versions that works with LZW files?
Thank you in advance to everybody for the help...
MarcoA
Re: Error Processing TIFF 1bit files with LZW compression
MarcoA wrote:Hello everybody!
The command is:
MarcoA
Do you know the size in pixels?
MarcoA
Post by MarcoA »
Hi, Pierre!
Thanks for the reply!
The size of the original Tiff 1 bit file (2400 dpi) is 49600 x 38734 pixles.
The target (150 dpi) should have a dimension of 3100 x 2421 pixels.
Note that if the same original file is compressed with CCITT 4, everything works fine!
Do you have any idea?
MarcoA wrote:Hi, Pierre!
Really?? Is it possible to have this file?
MarcoA
Post by MarcoA »
Of course it is possible!
If you have an FTP site, please give me via PM the address and the login, so I could upload both the original file versions, the CCITT4 and the LZW.
Looking forward to your reply,
Thank you very much once more for the support!
Marco.
