Displaying multi-layered PSD files in a single merged view
aladen
Post by aladen »
Hi Pierre,
Since last releases (1.9x ?), XnView display multi-layers PSD files in separeted layers (with the ability of browsing between this layers). But I cannot get a merged view anymore. Is this feature definitly gone ? Is there a way to tweak it ?
Merci pour les conseils et pour XnView que j'apprécie depuis des années !
David.
Ok I get it ! The problem occur when there are channels in the PSD file. XnView seems to render it as alpha channels and hide various areas of the layers.
Maybe should it be possible to switch off the channel in the display menu ?
Re: Displaying multi-layered PSD files in a single merged vi
aladen wrote:
Hi Pierre,
David.
XnView only show pictures found in the psd... There is no render
