1.91.6: Prev and Next file buttons state after fullscreen
ckv
Post by ckv »
Not a bug, but... State of the Previous and Next file toolbar buttons isn't updated after using the fullscreen.
To demonstrate the problem:
- Open folder with multiple images in XnView browser
- Open first file in the folder to view mode and then fullscreen the image
- While in fullscreen go to last image. E.g. With End button
- Exit fullscreen and look at the Previous and Next file toolbar buttons
ckit
Post by ckit »
This is normal if you have "Loop on file list" enabled for View options.
ckv
Post by ckv »
ckit wrote:This is normal if you have "Loop on file list" enabled for View options.
Good note. So when trying this make sure "Loop on file list" option is disabled.
Dreamer
Post by Dreamer »
Not a bug, so moving to "General Support".
Dreamer
ckv
Post by ckv »
Dreamer wrote:Not a bug, so moving to "General Support".
I beg to differ. I know I said that is is not a bug myself, but in some cases this behavior makes the "Previous file" and "Next file" toolbar buttons unusable...
- Make sure the "Loop on file list" is not enabled in View options.
- Open folder with multiple images in XnView browser.
- Open first file in the folder to view mode and then fullscreen the image.
- While in fullscreen go to last image. E.g. With End button.
- Exit fullscreen and try to click "Previous file" or "Next file" button in toolbar.
Partially---
:arrow: ckv
:) Hello !
• I can confirm partially, there is a minor misfeature here :
- Following your steps, here the two buttons are "ON" while I'm on the last file of the folder (via End in full screen).
- Of course, the Next button might be greyed out, but it's not, and does nothing.
- The Previous button works, browsing 2… 3 files back, and then using Next again up to the last file,
the Next button turns greyed out now like it should.
- Read as loop is OFF.
:mrgreen: KR
ckv
Re: Partially---
Post by ckv »
Clo wrote::arrow: ckv
:) Hello !
:mrgreen: KR
If you open the first file in the folder the Previous button should by greyed out so when you get out of the fullscreen both buttons do nothing cause the Previous is still greyed out. :)
You can also just hit the Previous button button untill you get to the first file and then go in fullscreen.
