Global conversion of files
tzud
Post by tzud »
I have 9000 tif pix which I want to convert to jpeg to fit on a single (?) DVD. Can the tif files be converted with a single command or must they be converted folder by folder?
No branch view…
—> tzud
:) Hello !
• I guess that it should need a “Branch” (flat) view, without any tree structure,
AFAIK that's not supported to choose all files to convert as one go.
• Hence, I think that you'll have to add the folders one by one onto the convert box… Good luck !
- BTW : You might try to define prior the total size in order to make you sure that it fits in the DVD …
:mrgreen: KR
Troken
Post by Troken »
Maybe it would work if you in the menu -under "View"- select "Show files in subfolders". Then all files would be displayed.
solid
Post by solid »
Yes it is possible.
Select all the folders in the browser you want to convert and call "Batch convert" Ctrl+U.
Or, just open the "Batch convert" dialog and press "Add folder..." button and point it to the folder where all the files and dirs are.
