I have the wish, that a customizable startup view would work like other programs offer
% of windows --> could be a percentage of the fit options (see bottom of post), like let me say 95%
then the picture ist displayed in an dimension of 95% of fitting size
it makes working in cropping and editing modes much easier.
Thank you
_____________
No fit
Fit window to image
Fit image to window, all
Fit image to window, large only
Fit image to desktop, all
Fit image to dekstop, large only
Fit image to window width
Fit image to window height
custom view in "Auto Image size"
Re: custom view in "Auto Image size"
Ok, really useful??fritzxnview wrote:I have the wish, that a customizable startup view would work like other programs offer
fritzxnview
Yeah,
if i want to cut an image, i move the mouse from outside the picture into it.* (for example: from right bottom corner) And so the first cropping area is defined.
A second mouse movement from the top left corner outside into the image defines the second cut.
And that would be all. Two steps for cutting (cropping).
In normal mode, the picture resizes to fit the whole window. So i have to zoom down, make the cropping step and so on and so on.
If there would be the feature
auto-fit to [95 or 97 or 85 or 20, whatever I wish to autofit] percantage of window
cropping is as easy as can be. No more need of using NUM+ or NUM-Keys.
I think it is a feature that is only interesting in cropping mode. Not in view mode.
Thank you
* This is one of the most useful features for fast cutting, because other programs don't have this
Thank you
