Description Files
G_down_Under
Description Files
Post by G_down_Under »
I have Batch Renamed files using Version 1.91.5 and it mucks up the Descript.ion file, all the comments are out by 1. ????
Re: Description Files
G_down_Under wrote:I have Batch Renamed files using Version 1.91.5 and it mucks up the Descript.ion file, all the comments are out by 1. ????
1. ??? what do you means?
foxyshadis
Post by foxyshadis »
I think you'll have to manually restore the file names. Have you tried 1.91.6?
Pierre, he means that it went like:
File 1 -> Description 2
File 2 -> Description 3
File 3 -> Description 4
Or perhaps vice versa, after a batch rename (they don't match the right file).
