scanning problem with hp 2210
Wil
Post by Wil »
hi,
i am a very fan of this programm so dont take my comment the wrong way.. It is the best and i hope its going on with its development! Wish you luck with it!
the bug is.. when i scan.. (just push the button to scan) and its finishing his scan it doesnt import the image directly into xnview (1.96...) sometimes it does it, but after a while it doesnt.. and in word (i tried other programms to) no problem .. the scan works...
would be nice to have a soluccion..
thanks and until next time..
Wil
Re: scanning problem with hp 2210
Wil wrote: the bug is.. when i scan.. (just push the button to scan) and its finishing his scan it doesnt import the image directly into xnview (1.96...) sometimes it does it, but after a while it doesnt.. and in word (i tried other programms to) no problem .. the scan works...
Only sometimes, it works????
