Colors messed up when inserting Screenshots
Post by Guest »
Hello everyone,
I "take" the usual screenshots with the Print-Button.
When I want to insert this screenshot with CTRL+SHIFT+V into XnView, it looks like this:
How can I fix this?
(My video card is a ATi X1400.)
P.S.:
I'm sorry I didn't register, I'm just tooo tired to go through the whole process right now.
foxyshadis
Post by foxyshadis »
Xnview has always done very strange things with print screen when it's open, for me, though I never got around to reporting it. Oddly, I have the same card, though it occurred on a 9200-based laptop as well. (I get 1-bit monochrome output, not even 8-bit like you.) The only way you can get good screenshots while it's open is to use xnview's screen capture utility (Tools, Capture Screen), not the system's.
I suppose it would have been a good idea to mention this a while back.
As an aside, this function really needs a shortcut, and also really needs to have the print screen key itself in the list of hotkeys. I mean, it only makes sense, and it's no harder to hook.
Fixed in last
:arrow: Guest
:) Hello !
• I use PrintScreen and also Alt+PrintScreen a lot in XnView,
for instance to make images for the Manuals, and that works in the last 1.91.6.
• There was a bug like you show (or very similar) in previous versions1.9xxx that I reported HERE.
- It's fixed, I checked that again now.
- However, a minor bug remains : in some cases, when you have set a button for the “Import Clipboard” function
and want to paste a capture of XnView itself just made before, that button stays grayed while it might be enabled.
- That works from the menu, though…
- I've an onboard video with an Intel mother-board, and set 16 BPP only @ display.
- The bug occured with that colour depth only, like said in the French thread linked above.
- XP-Pro SP1 (FR-Eng.).
:mrgreen: Kind regards,
Re: Colors messed up when inserting Screenshots
Anonymous wrote:Hello everyone,
Which version do you have?
oops66
Post by oops66 »
It works on Win98SE (for windows 16 and 32 bit screen display), maybe it's an OS related bug with XnView ? (for the gray color ?)
Like here : http://newsgroup.xnview.com/viewtopic.p ... &highlight
Could you please tell us the Windows version you are using?
What's the numer of colours /colour depth used on your system (Right click on free area on desktop, menu item "Properties", Folder tab "Settings" shows the value)?
enrico
Post by enrico »
helmut wrote:Could you please tell us the Windows version you are using?
Hello everyone und juten Abend Helmut.
I'm the one "invité" who started the thread.
Long story short: Accidently reading only Helmut's post, I thoght I might try changing the depth to 32bit (yes, it was set at 16bit before) and then re-do everything. It worked, so thanks for suggesting indirectly it might be the colour depth. :)
Some facts, if anyone's interested:
XnView Version: 1.91.1 (Jun 11 2007)
OS: WinXP SP 2 + all updates available (in German, of course)
Plz upgrade
—> enrico
:) Hello ! Welcome aboard as a Member !
• You might upgrade to 1.91.6 because that bug is totally fixed (except the minor issue I describe above).
No more problem with 16 BPP now.
- 1.91.1 had the bug with 16 BPP, and strangely, when you switched from 32 BPP to 16 BPP, the bug didn't occur.
- We had it only when booting Windows with 16 BPP already configured before…
:mrgreen: VG
enrico
Re: Plz upgrade
Post by enrico »
Clo wrote: • You might upgrade to 1.91.6 because that bug is totally fixed (except the minor issue I describe above).
Hi Clo, thanks for the nice welcome!
I just upgraded, so everything should be working fine ... :)
See you!
