I edited IPTC field "description" in my photos using Xnview. When I look at them in Picasa I don't see full written text. Only some letters or words.
Other applications like Irfanview, Exifer see full text in this field of my photos.
Are there any problems with writing in standard form this IPTC description field by Xnview?
Picasa don't read properly IPTC description edited by Xnview
D-rec
Re: Picasa don't read properly IPTC description edited by Xn
Perhaps picasa use XMP to write IPTCD-rec wrote:I edited IPTC field "description" in my photos using Xnview. When I look at them in Picasa I don't see full written text. Only some letters or words.
D-rec
what code page in IPTC description field
maybe there is the problem with code page of characters in IPTC description field? I describe photos in Polish.
foxyshadis
Re: what code page in IPTC description field
XnView has no unicode capability, unlike most software, so that's probably where the problem comes from.D-rec wrote:maybe there is the problem with code page of characters in IPTC description field? I describe photos in Polish.
Could you send me a sample file?D-rec wrote:maybe there is the problem with code page of characters in IPTC description field? I describe photos in Polish.
