Extract image number from the file name
Lapinoo
Post by Lapinoo »
For some reason, I like to reuse the image number of an image when I rename images. For example, if a file is named IMG_2532.jpg, I would like to reuse the 2532 value in my naming template.
I keep this information to have be sure images are in the right order when I shoot 5 frames per seconds and the second is not enough to name the images.
marsh
Post by marsh »
Function exists in batch rename's name template: <Filename Number>
Lapinoo
Post by Lapinoo »
Wooops... Silly me!
