I've installed the latest XNView onto a fresh Wxp, all updates. The problem: Even though I'm using xnview file association option, double clicking e.g. a .jpg starts: Windows image and fax viewer.
I xnview doing enough? I remember theres also a "filexts" tree node under hkcu\ms\windows\explorer\... and I'll have a look at that...
File associations do not work
Re: File associations do not work
Do you use option/Association in xnview?Guest1234 wrote:Hi,
