Problem with Companion Files in 1.91.6
andrewj
Post by andrewj »
I have just upgraded to 1.91.6, but I can't get the new companion files feature working, and the default companion file handling (which was fine in 1.914) seems to be disabled.
Firstly, I want to move/copy .JPG files when I move/copy the RAW file (.CR2). This was default behaviour before, but seems to have stopped working.
Secondly, I'd ideally like to move, at the same time, the Bibble Pro sidecar file (which will have an extension of .CR2.bib). Can this be done?
Thanks
Andrew
Re: Problem with Companion Files in 1.91.6
andrewj wrote:I have just upgraded to 1.91.6, but I can't get the new companion files feature working, and the default companion file handling (which was fine in 1.914) seems to be disabled.
Do you have tried to change the CompanionFile in xnview.ini?
andrewj
Post by andrewj »
Dear Pierre,
Yes, I tried the following entries under [File]
Companion_00=cr2:jpg
Companion_01=cr2:cr2.bib
Is this right? I couldn't get it working.
Thanks
Andrew
andrewj wrote:Dear Pierre,
Thanks
Andrew
Perhaps the bug that i have fixed for next release. If you want i can send you a test version to check?
andrewj
Post by andrewj »
Yes, please. I'd be happy to test it.
Andrew
andrewj wrote:Yes, please. I'd be happy to test it.
Andrew
Send me your email by PM
andrewj
Post by andrewj »
Dear Pierre,
I'm sorry, I still can't get it working, for either the jpg or bib files. My entries, in the [File] section of xnview.ini, are
Companion_00=CR2:jpg
Companion_01=CR2:CR2.bib
Have I mis-spelt something? Are the entries case-sensistive (I've tried several combinations, but not all).
Thanks
Andrew
Thanks
Andrew
Right a problem if you have 2 extensions... i'll fix it
andrewj
Post by andrewj »
Dear Pierre,
I'm trying to use the latest test version, and I've come across a problem. If I pick up and drag the .CR2 file, I want it to take the .JPG and the .CR2.BIB with it. This works fine.
However, if I pick up the .JPG I don't want to move the other files. This allows me to move this to a different output directory from the originals if I want to.
I've currently got the following two entries in the ini file:
I've got rid of the line mapping jpg to cr2.
Logically this should give me the behaviour I want. Can we fix this?
Thanks
Andrew
Thanks
Andrew
Ok right. Currently i check cr2=>jpg AND jpg=>cr2!
andrewj
Problems Solved - Need to Update Help File
Post by andrewj »
:D
Pierre - thanks for fixing this. It works like a dream now.
I suggest we need a couple of lines of instruction added to the "companion files" page in the help file. If it helps, I've drafted the following as a starter:
XnView allows you full control over how companion files are managed. You turn companion file handling on and off in the "File Operations" tab under Tools/Options.../"General". The detail behaviour then depends on lines in the [File] section of XnView.ini
For each pair of file types, you need a line like:
This means that file operations such as move, copy and delete on a Canon RAW file with extension .CR2 will also affect the companion file with extension .JPG
You can have up to 100 associations, but each line must have a different number before the "=" sign.
The system can also accomodate files where a new extension is appended to the original one. E.g. Bibble adds .bib to the RAW filename, so you need a line like the following:
The associations only work one way. E.g. the above only work if you act on the .CR2 file. This makes it easy to manage output files separately from the other associated files. If you want the associations to work both ways you will need lines mapping the other way, e.g.:
Companion_02=cr2:jpg
JohnFredC
Post by JohnFredC »
This is very helpful text. Thanks for it!
John
Thanks for this good, explaining text, Andrew. Perhaps Ty can add this to the XnView online help.
Peter2
Re: Problems Solved - Need to Update Help File
Post by Peter2 »
andrewj wrote:...to work both ways you will need lines mapping the other way, e.g.:
Other way? The code is the same as in the first example. I thought that this example is right:
Companion_02=jpg:cr2
Peter
sternenfall
Post by sternenfall »
Just a note for "Companion_xx". To represent the relationships between JPG/TIFF/ORF/CR2 I have to use 30 entries in XnView:
Companion_00=jpg:tiff
Companion_01=tiff:jpg
Companion_02=jpeg:tiff
Companion_03=tiff:jpeg
Companion_04=jpg:tif
Companion_05=tif:jpg
Companion_06=jpeg:tif
Companion_07=tif:jpeg
Companion_08=cr2:jpg
Companion_09=jpg:cr2
Companion_10=cr2:jpeg
Companion_11=jpeg:cr2
Companion_12=orf:jpg
Companion_13=jpg:orf
Companion_14=orf:jpeg
Companion_15=jpeg:orf
Companion_16=cr2:tiff
Companion_17=tiff:cr2
Companion_18=cr2:jpeg
Companion_19=jpeg:cr2
Companion_20=orf:tiff
Companion_21=tiff:orf
Companion_22=cr2:tif
Companion_23=tif:cr2
Companion_24=cr2:jpeg
Companion_25=jpeg:cr2
Companion_26=orf:tif
Companion_27=tif:orf
Companion_28=orf:jpeg
Companion_29=jpeg:orf
Apparantly the reason for the inflationary application of "Companion_xx" is that "JPEG"/"JPG" and "TIFF"/"TIF" are separate extensions. Also the declaration is only one-way. Suggestions:
  • use "::" instead of ":" to indicate bidirectional binding
  • use ";" to separate multiple extensions
For example:
Companion_00=jpg;jpeg::tif;tiff
could replace 8 definitions:
Another problem is that XnViewMP 0.39 seems not so supprt "Companion_xx".
This might by natural, however, since its ini-file not even has a "[File]" section. :)
Greetings, Andreas
