Fullscreen doesn't work
reanimator
Post by reanimator »
The problem is, when i press F11 key (fulscreen), the title bar of the window doesn't disappear, it just becomes 'frozen'
I'm using latest version. Windows XP on Dell latitude c640 laptop.
Thanks.
Stollen ?
—> reanimator
:) Hello ! Welcome aboard !
• F11 works perfectly here in 1.91.6. Please, check whether the Dell's stuff isn't stealing that shortcut,
that's not rare (especially with this mark of PCs…).
:mrgreen: Kind regards,
reanimator1
Post by reanimator1 »
I tried to post screenshot and got banned :(
Clo, the same thing happens when i select View->Fullscreen from menu.
Screenshot is here:
smirnovtabs dot narod dot ru slash fscr dot jpg
Try parameter…
—> reanimator1
:) Again…
• I got your image, it's a quite honest landscape, so I dont know why it could cause you have been banished…
- Maybe is it too large ? Or is the domain (wrongly) black-listed ? :?
• Anyway, it's odd, since only the title-bar remains, like you said.
- AFAIK, there is no option to keep the title-bar in full screen.
• Please, try that follows :
1. Start XnView from a command-line with the parameter -full to see that occurs. Is the title-bar displayed still ?
2. Test the same image as full screen in another computer (any but a “Dell”).
3. If you display the tool-bar normally, is it hidden ?
:mrgreen: KR
reanimator1
Tried with -full parameter but it doesn't help.
I tested it on friends' computer (not Dell) and fullscreen works without problems.
So it's really Dell's fault, not xnview's.
Thanks for help.
