-Mike
Support for pi2 files
Mike
pi2 file extension
-Mike
I miss samples
• “degas ¦ Degas & Degas Elite ¦ pi2”
is alright listed as supported at reading and writing like shown HERE.
- Unfortunately, I don't own such files (old, I guess…) to check.
- I think that a¦some sample¦s is¦are desirable…
Please have a look at FAQ "Does XnView support graphic format .xyz?". Especially marsh's hint should be interesting.
EdwardM
Pi2 Files help
I have not been able to get plug in or make program show pi2 files. The above posts say to go to General>Starup to check the required box. I have not been able to find where that may be in version 1.90.4. Can anyone help?
Thanks
Ed
Ed
marsh
EdwardM
PI2 Files
Thanks I checked off the box but still no viewing of pi2 files. I reinstalled XnView-full & installed the plugin Zip file. None of this worked. The plugin directory does not have anything like pi2 or degas dlls. Is there somewhere else I can go for the needed plugin or am I missing something?
Thanks
Ed
Ed
Re: PI2 Files
PI2 is Degas format, perhaps you have Protrait innovation files (crypt format)
