When I try to use fullscreen or slideshows with .nef files, Xnview, only renders the image with low quality -ignoring the "high quality" Raw setup that is set to read RAW files-, which is usefull if you use an old computer (and low resolutions too).
The main problem is that if you try it with new computers with big displays and greater resolutions, the image Doesn't Fill the screen, it happends to me with 6Mp Nef files (because width and length is halfed).
So the suggestion is to let the user able to setup if he wants high RAW quality when using fullscreen and slideshows.
Thanks for creating such a great program
Fullscreen NEF (RAW) rendering
Re: Fullscreen NEF (RAW) rendering
This option is only used for convert, please use option/View/Misc/Camera RAWtokinger wrote:When I try to use fullscreen or slideshows with .nef files, Xnview, only renders the image with low quality -ignoring the "high quality" Raw setup that is set to read RAW files-, which is usefull if you use an old computer (and low resolutions too).
tokinger
Damm it... I don't know how did I missed it, it seems that this new interface it's a little bit tricky for me.
Thank you, a great program... with greater support
