I'm having a problem adjusting the white point for levels on xnview's batch mode. If I set the black point and white point to say
(85,210) which works well to clean up black and white text, it seems to only set the black point but not the white point. When I save the script, the levels command says...
Levels ( 85 )
when I open the script in notepad.
Changing the script manually in notepad doesn't seem to work either to Levels ( 85 , 210 ).
Has anyone else experienced this problem?
xnview batch levels command not accepting white values
Re: xnview batch levels command not accepting white values
It's fixed in 1.91.6
