I have tried several times De-Skew an image, but the results varies:
-Usually nothing happens
-Image gets rotated by random degree
Or how the De-Skew should actually work then...?
<EDIT>Added version number to subject</EDIT>
1.91.6: De-Skew...random?
Markus
B&W - Grey---
—> Markus
Hello !
• This fiunction is for Black & White and Grey-scale images only,
please see THAT THREAD (and some others from the Search…
KR
Markus
Markus
Made some tests...
Most correct results I can get, if I have a high contrast image, or draw a black line on white background.
If I have an image rotated with XnView without cropping and select the edge of rotated image (greyscale!), where is high difference in grey values, and try De-Skew, nothing happens.
In the same image those black lines on white causes an action and the imake gets rotated more straight.
I can believe, that it have to be very difficult to get program finding out of image, which is the line the user means to be straight...
Also, came in my mind, that why could De-Skew work on coloured images too, if the routine first would think image as an greyscale..?
