[Fixed] HistoBColor=… Colour code issue
:arrow: Pierre
:) Hello !
• That new entry is not added automatically by the programme in an already existing INI, thus I added it by hand.
- Unfortunately, it doesn't support the colour code as plain RGB (decimal) like i.e.
HistoBColor=255 255 213 ( cream), I get a red BG instead.
- The HTLM code #RRGGBB is not supported either (and also certainly the reverse hexa code $BBGGRR).
- Using the “complements” is a stick in the b**, please, could you change that in the next beta ? TIA !
:mrgreen: KR
oops66
Re: HistoBColor=… Colour code issue
Post by oops66 »
Clo wrote::arrow: Pierre
:) Hello !
:mrgreen: KR
Same behavior here too.
All codes !
:arrow: Pierre
:) Fixed in ß-2 !
- All codes (plain decimal, normal & reverse hexa) work! Thanks !
:mrgreen: KR
