[Fixed] ColorFilter… & BColorFilter… (new, custom)
:arrow: Pierre
:) Hi !
• That works, thanks, but not totally, for instance the syntax :
ColorFilter26=*.txt, 255 185 151
renders alright a light-orange font as expected, while it's BG in the same painting :
BColorFilter26=*.txt, 0 0 0
is not black as it should, but “almond-green” {•} …
:mrgreen: KR
Re: ColorFilter… & BColorFilter… (new, custom)
Works for me, you have 25 BColorFilter before BColorFilter26?
Complete
:arrow: Pierre
:) Hello !
• Yes, the bunch of entries is complete :
BColorFilter24=ani, 217 247 227
BColorFilter25=fpx, 229 255 255
:mrgreen: KR
Re: Complete
And you have default back color?
It seems---
:arrow: Pierre
:) It seems, it's "almond", something like 224 255 224 on a capture or close like shown above within { },
I can't say exactly because it's set as "complements" code :
BackListColor=14811105
BackgroundColor=16757683
BorderColor=6684774
:mrgreen: KR
PS :
YEP ! 3 000 ! :D
Re: It seems---
For me all is ok
marsh
Re: It seems---
Post by marsh »
Clo wrote::arrow: Pierre
:) It seems, it's "almond", something like 224 255 224 on a capture or close,
BorderColor=6684774
:mrgreen: KR
PS :
YEP ! 3 000 ! :D
Confirmed.
BColorFilter26=jp2, 237 237 202
BColorFilter27=*.txt, 0 0 0 ------>Matches whatever BackListColor is (the next ini item)
BackListColor=32896
Re: It seems---
marsh wrote: Confirmed.
BackListColor=32896
In which mode? Thumbnail?
marsh
Re: It seems---
Post by marsh »
BackListColor=32896
No, in details column list.
Re: It seems---
BackListColor=32896
Ok, right, i've found it. The problem is only with black :-)
Won !
:arrow: marsh
:) Hi B. !
…BColorFilter27=*.txt, 0 0 0 ------>Matches whatever BackListColor is (the next ini item)
• You win the Silver Salad Bowl ! At least in “Details” mode.
- I changed the BG to light-grey 235 235 235 and I get it instead of the wanted “Black”
:arrow: Pierre
- I'm talking of “Details” display.
- In thumbnails mode, I get the BG of the thumbnails, but not the stated "Black",
that indeed is unreadable since here it's a light-orange font on a very light-purple BG !
:mrgreen: KR to All
ß2 —> fixed !
:arrow: Pierre
:) It's fixed in ß2 ! Thanks !
Now, I've to test with several customized entries…
:mrgreen: KR
