When I view the EXIF User Comment with XnView, I only get the first character of the commen showing.
The comments are inserted using Windows Explorer (Vista64) and/or ACDSee. The comments show up fine in both these areas, but not when viewed with XnView.
Any ideas - am I doing something wrong?
Thanks in advance
Volt
EXIF user comment only shows first character of comment?
Re: EXIF user comment only shows first character of comment?
Could you post a sample or send me it?volt wrote:When I view the EXIF User Comment with XnView, I only get the first character of the commen showing.
