RPF reading of extra layers
vykupitel
Post by vykupitel »
Hello Pierre,
for the first many thanks for your superior work in Xnview.
I'd like to ask if would be possible show extra layers in RPF/RLA format like Z-depth and so on? Would be nice to switch them with "M" hotkey which show alpha mask.
Thanks,
Lada.
Re: RPF reading of extra layers
vykupitel wrote:Hello Pierre,
You would like to view z-buffer as alpha channel?
vykupitel
RE
Post by vykupitel »
My bad, I mean that would be nice to somehow show other layers of RPF for example like alpha mask is shown by hotkey "M".
vykupitel
RE
Post by vykupitel »
Hello, I'd like to revive this old topic. I use Xnview in production environment and I will be very happy if it would read also other channels from RPF like Z-Depth/Opacity/Coverage/Colour/...
Pierre, do you think that it would be in future implemented into superb Xnview?
Re: RE
vykupitel wrote:Pierre, do you think that it would be in future implemented into superb Xnview?
Not easy, but could you send me a sample?
vykupitel
RE
Post by vykupitel »
OK, no problem. Here is setting of exported layers:
and here is file:
http://www.volny.cz/vykupitel/Pictures/rpf/test.rpf
thibaud
Post by thibaud »
that would be just wonderful indeed.
Here is a floating point .rpf file for testing as well.
http://www.thibaud.be/dropbox/rpf_test32.rar
also .rpf being a format that is condemned to disappear sooner or later in favor of exr.
it would be great to see this functionality accessible for exr files as well.
Pierre, let me know if you need some exr samples.
