Watermark dialog: Negative values for Spacing
In 1.92 B2 the values for spacing can be negative. I doubt that this should be possible.
marsh
Re: Watermark dialog: Values for Spacing
Post by marsh »
helmut wrote:In 1.92 B2 the values for spacing can be negative. I doubt that this should be possible.
I think it should. In fact, it might be a bug for it not to. The reason is that a negative value would allow you to drag watermark image partially over one of the corners. If you see what I mean... which isn't always possible for the moment with all the corners. :bug:
There is a little bug with negative offset, but negative values are useful
xnview wrote:There is a little bug with negative offset, but negative values are useful
I understand the sense of negative values, now. More details and discussion in topic Watermark dialog: Spacing has wrong effect.
