Salut,
Would you please consider to create an updated version of NConvert for OS/2?
Me as the author and the users of my FotoGet/2 application, that relies on NConvert to provide preview and basic rotation features, would be more than happy if NConvert for our aging but still beloved OS/2 would get updated.
Thanks for your efforts,
Herwig Bauernfeind
NConvert for OS/2 - any hope to get an updated version?
Re: NConvert for OS/2 - any hope to get an updated version?
I've put a new version of NConvert for OS/2 on http://www.xnview.com/beta/nconvert-OS2.zipHerwig B. wrote:Would you please consider to create an updated version of NConvert for OS/2?
Tell me if it works fine?
Herwig B.
NConvert for OS/2 - beta
Pierre,
thanks a lot.
I will test it myself and provide it to the limited audience (~25 people) of my FotoGet testers to get more opinions and results.
A Merry Christmas to you and your family!
Best regards,
Herwig B.
thanks a lot.
Best regards,
Herwig B.
Herwig B.
NConvert for OS/2 4.42 beta - no problems so far
Salut Pierre,
the beta build you provided in late December 2004 seems to work fine, at least those things that are required by FotoGet.
Now my question: Is there a test suite you run your builds on other platforms to make sure everything works?
I'd like to setup such a test suite for the OS/2 build of NConvert and if possible I would not want to reinvent the wheel.
Best regards and keep up the good work,
Herwig
Herwig
