Folder Background Colors "Discovery"
JohnFredC
Post by JohnFredC »
I have folders that display different folder background colors in XnView!
  • 1. I'm crazy for not noticing this before.
    2. It makes perfect sense (because the folder thumbs are stored in the cache?).
    3. I LIKE IT!!! Having different folder colors for different folders is great!
    4. Please make this easier to control:
John
Re: Folder Background Colors "Discovery"
JohnFredC wrote:I have folders that display different folder background colors in XnView!
You have change the colors for folder thumbnail, and not rebuild them.
You want different color per folder????
JohnFredC
Post by JohnFredC »
xnview wrote:You have change the colors for folder thumbnail, and not rebuild them.
Yes. Makes me consider a strategy to preserve the folder color between thumb re-builds.
xnview wrote:You want different color per folder????
I didn't think so before, but now that I have it (temporarily, at least)... it actually looks useful! A user would need to be able to conveniently access a folder color dialog from the folder context menu, though... having to modify the INI "by hand" precludes wide adoption, otherwise.
Perhaps integration with a "folder color category" feature would be useful, too.
John
