1.91.6 Display bug: text information in 100% view
MarkusF
Post by MarkusF »
Hi all,
i have setup some information that i can display with "I" key. Problem is when i zoom to 100% view (* key) and move the mouse around, the text "smears" across the screen like this:
Seems like an overlay bug. I have a AMD Athlon64 3700+ processor, 1 GB RAM, Ati Radeon X800 GTO graphics card with latest ATI catalyst drivers ... funny enough, it works on my Intel office pc with a Radeon7000 and catalyst drivers.
Any thoughts on this?
Thanks,
Markus
Re: 1.91.6 Display bug: text information in 100% view
Do you reproduce it with 1.92 beta? I can't with the beta
MarkusF
Post by MarkusF »
xnview wrote:Do you reproduce it with 1.92 beta? I can't with the beta
Pierre,
thanks so much for you reply. I just found and picked up 1.92 beta 3 and will try again this evening and reply if i was successful or not.
Regards (and a big thanks for creating xnview),
Markus
MarkusF
Update on this bug
Post by MarkusF »
i tried 1.92 beta yesterday and it worked perfectly with this one.
Now here comes the funny thing: i started 1.91.6 again to see if the error is still there and indeed it was. Then i jumped to the options screen and played around a bit with the information display settings ... changed to a different font (Courier new instead of Courier) and *BANG* it worked in 1.91.6 too! :shock: I changed back to Courier and it STILL worked.
I did not have time to look into that more deeply, but i will this weekend.
Regards,
Markus
