Possible to turn off # / numeric enumerator?
Mango
Post by Mango »
I've tried searching the forums, and I can't seem to find a solution to this problem. I'm converting a bunch of pictures with the "-o c:\abc\%" like syntax. However, if the original picture has a "#" character, it must treat it as "position of numeric enumerator" which basically means if I had an original picture named "sarah#.jpg" it would convert it to "sarah0.jpg", or "sarah1234.jpg" depending I guess on the pictures that came before it?
Is there a way to turn this "#" feature off?
Mango
Re: Possible to turn off # / numeric enumerator?
Mango wrote:Hi,
No but i'll add it
