Has the keyboard timing for advancing to next image (in viewer) been changed?
When the <page down> key is pressed and held down for a few seconds:
v.1.92.6: After <pg dn> is released, viewer stops displaying images almost immediately.
B3: After <pg dn> is released, viewer *continues to advance through a great many images before stopping.
B3:Viewer: next image: held-down key behaviour
marsh
Re: B3:Viewer: next image: held-down key behaviour
Do you have the same settings?marsh wrote:Has the keyboard timing for advancing to next image (in viewer) been changed?
(Read Ahead) I can't confirm
marsh
Thanks, that solved it. With B3, read ahead was on. v.1.92.6 read-ahead was off.xnview wrote:Do you have the same settings?marsh wrote:Has the keyboard timing for advancing to next image (in viewer) been changed?
