[Lacuna] No “UNDO” button with «PhotoMasque»
:) Hello All !
• If you apply a mask from that filter, the “Undo” button remains greyed out when the operation is ended.
- It can't be undone directly.
- Currently, the only way is to close the file without saving it (and to disable the confirmation message before in the INI !)
:mrgreen: KR
marsh
Re: [Lacuna] No “UNDO” with «PhotoMasque»
Post by marsh »
Clo wrote: • If you apply a mask from that filter, the “Undo” button remains greyed out when the operation is ended.
Yes. For me, if I click on "whitespace" outside image: the undo button appears.
Like---
:arrow: marsh
:) Hello B. !
• Ah, right ! Anyway, that's abnormal…
- I noticed a similar hitch for another button in previous versions for another button (“Import clipboard”, IIRC…)
:mrgreen: KR
