Thumbnail handling in lossless JPEG transformations
Marcus Sundman
Post by Marcus Sundman »
It would be nice to be able to choose what to do with the embedded thumbnail when doing a lossless JPEG transformation.
The options could be:
  • perform the same transformation on the thumbnail
  • remove the thumbnail
  • don't do anything to the thumbnail
Re: Thumbnail handling in lossless JPEG transformations
Marcus Sundman wrote:It would be nice to be able to choose what to do with the embedded thumbnail when doing a lossless JPEG transformation. ...
Think that's a good idea and an important feature which should be supported, soon. Rotating the JPG image and leaving the thumbnail unchanged is only half the job. ;-)
Thank you, Marcus.
Yes, good improvment.
Marcus Sundman
Let me add two more options:
  • regenerate thumbnail if one exists
  • (re)generate thumbnail regardless of if one exists or not
