I'm sure the answer is here somewhere but I've tried searching and cannot locate it. How can I setup xnview to default certain batch settings? For example every time I open the batch processing window, I have to Click on the Transformation Tab (Which I wish had a keyboard shortcut, but I digress), "Image" is already expanded, so then I have to double click on Set DPI and then double click on Resize. Then I have to click the Resize Option in the Right side and actually enter the Width and height settings. The DPI has a default value of 72, which is good. I'd like to have the width and height have a default setting as well, so it didn't need to be entered every time.
So, two things I'm looking for:
1. To be able to default the DPI and Resize options on all batch processing
2. To be able to set default values for both of these options
3. More keyboard shortcuts so you don't have to mouse over to each option each time. Maybe CTRL + Letter combos.
I love this program and having these options would make it a lot easier to use, so I'm hoping someone can help me out. TIA for the help!
Set Default Settings
Re: Set Default Settings
Thank you, Ewek1, for your suggestions and accolade.
I guess you are aware that many menu items are available using the Alt key. Press the Alt key, then the accelerator character for each individual menu item is underlined. For example for "Image > Flip > Verically" you can press "Alt", then "i", then "f", and last not least "v".
Please let us know if you need a specific keyboard shortcut.
Ewek1 wrote:...
I see the ALT shortcuts, but they are really only for the Menu Toolbar Functions. It would be nice if they also related to the current screen, in this case the Batch Process Window.
I guess this means that putting a default value in for the resize option (and having the resize option be defaulted to ON) is not an option at this point?
