TI Bitmap
It's present
• That format is alright in the list, like below (in 1.92) :
Re: TI Bitmap
Do you have enabled Option/General/Use all formats?NunoMMachado wrote:I have installed the last version of XnView, but the format *.92i doesn't exist, as you can see the "Save as" list in the picture below.
An old version of XnView installed on old computer have that format.
Re: TI Bitmap
From what I can see there is no option "Use all formats" in XnView 1.92 . I think it's labeled "Display all image file types", now.xnview wrote:Do you have enabled Option/General/Use all formats?NunoMMachado wrote:I have installed the last version of XnView, but the format *.92i doesn't exist, as you can see the "Save as" list in the picture below.
Changed, but the format is there
• You are right, it's changed (not in French, though…)…I think it's labelled "Display all image file types", now.
• Anyway, when that box is ticked, the TI Bitmap format IS in the list, like I showed above.
Re: TI Bitmap
Good to read. Thank you for your feedback!NunoMMachado wrote:Thank´s!
I can save now .92i format.
