1. It doesn't work at all in Browser fullscreen.
2. It can't be disabled, only enabled - "Lock zoom" shortcut toggles the lock, "Lock fit" might be working the same. It's not a real but though.
XnView 1.92, Windows XP SP2.
1.92 - Lock Fit only as shortkey Ctrl+numpad *
Dreamer
Re: 1.92 - Lock Fit only as shortkey Ctrl+numpad *
I can't confirm
Dreamer
Strange. Here are steps to reproduce:
Edit: I have tested all in resolution 1680x1050, so please try this resolution, if possible, or any 16:10 AR resolution.
1.
- use option "fit image to window, large only" by default
- open large 3:4 image (4MPX) in browser fullscreen
- press num *
- image is enlarged to whole screen
- press ctrl+num * to lock fit
- press page down (to 4:3 large image), then page up
= image is fit to window/screen again - "lock fit" doesn't work
2.
- open large 3:4 image (4MPX) in edit fullscreen
- press num *
= it works good, "lock zoom" is enabled
- now press ctrl+num * again to disable it
- switch to other image
= it's not disabled, "lock zoom" is still enabled
3.
I found another bug.
- open large 4:3 image (4MPX) in edit fullscreen
- press num *
- image is enlarged to whole screen and centered
- press page down (to another large 4:3), then page up
= "lock zoom" is enabled, but the image is not centered, the bottom of image is visible!
= same results if using num 1 instead of num * in the 3rd step
"Lock zoom" works good also in 1680x1050 / 16:10 resolution.
1.
- press num *
2.
- press num *
3.
- press num *
Dreamer
Dreamer
