Double separators
Troken
Double separators
Post by Troken »
When I select an image in the browser following appears between the tree and the preview:
:bug: ?
EDIT: Im using layout 8.
Tree and preview
:arrow: Troken
:) Hello !
• I tested with that layout (mine is #4), at first use the tree is hidden,
hence you have to use the arrow at the very left side to adjust its width.
- Testing a second time, that adjustment is saved. Also in another session.
:mrgreen: KR
Troken
Post by Troken »
Aha, it has to do with:
View -> Preview pane -> Use vertical layout
Clo, as you said, after adjusting the separator once, the problem disappears (I think).
If "Use vertical layout" is not selected, this happens. Selecting it, the problem disappears. So a bug when not "Using vertical layout" (first time)?
