[1.92] Menu in fullscreen/icons and sys buttons shown twice
Re: [1.92] Menu in fullscreen/icons and sys buttons shown tw
Anonymous wrote:Same bug that this:
http://newsgroup.xnview.com/viewtopic.p ... highlight=
Really??? But it has been fixed??
Post by Guest »
Hi Pierre,
Since 1.91.6 this bug is present in my system, The new 1.92 has the same error in my XP SP2. I back to 1.91.5
Thanks for this fantastic program.
Post by Guest »
If i install 1.92 over 191.5 the menu is show twice in fullscreen mode
With a fresh install of 1.92 the bug is not present????
Any solution
Thanks in advance.
Anonymous wrote:If i install 1.92 over 191.5 the menu is show twice in fullscreen mode
Any solution
Thanks in advance.
??? Are you sure that you have the 1.92??
Post by Guest »
Yes Pierre...
If I delete de xnview.ini, the bug disappear...
Fullscreen:
Version:
Thanks again.
Anonymous wrote:Yes Pierre...
Fullscreen:
Thanks again.
And you have the bug if you double click on picture in widnows explorer?
Post by Guest »
No...
Only with a double click from xnview browser..., and if click f11 the view is normal :shock:
Post by Guest »
Voila!!
Changing Doubleclick from:
Browser>Fullscreen>Viewer
to
Browser<>Fullscreen|Viewer<>Fullscreen
and ok
Thanks for your efforts :D
Dreamer
Post by Dreamer »
It looks it works good only in one fullscreen mode, but I can't reproduce it in 1.92.
Dreamer
Anonymous wrote:Voila!!
to
and ok
Ok, i can reproduce it with these settings!
