I've noticed that Xnview shows the incorrect image size when I hover over a thumbnail. The images are Olympus' RAW format; .orf. Xnview shows the image to be 3720x2800 when really the image is 3648x2736. Any ideas why this would be happening? Thanks!
--edit--
Olympus Master (their RAW editing software) shows the images size correctly at 3648x2736(this size is supported by their documentation).
Also, when I do a batch convert of my .orf files to a .tif the image size gets cut in half. Example: 3720x2800x48bit get converted to 1860x1400x24bit instead of becoming a 3720x2800x24bit .tif file. (Keep in mind though that the 3720x2800 is the incorrect size). Thanks again!
Incorrect Image size displayed
Re: Image size
Could you send me such file?j-dog83 wrote:I've noticed that Xnview shows the incorrect image size when I hover over a thumbnail. The images are Olympus' RAW format; .orf. Xnview shows the image to be 3720x2800 when really the image is 3648x2736. Any ideas why this would be happening? Thanks!
--edit--
j-dog83
Image available
Image available at http://www.justinandmichelle.us/image.ORF
Re: Incorrect Image size displayed
Ok, it's normal, xnview can only load it as 3720x2800px, and you must check option/Read/Camera RAWj-dog83 wrote:I've noticed that Xnview shows the incorrect image size when I hover over a thumbnail. The images are Olympus' RAW format; .orf. Xnview shows the image to be 3720x2800 when really the image is 3648x2736. Any ideas why this would be happening? Thanks!
--edit--
