Hi everybody,
I just installed XnView, and I am trying now to convert PDF image to JPG.
No success. When I click Convert and then Go, I am prompted that the the format of the file *.PDF could not be determined.
I tried also with a .DOC file, getting the same prompt.
Please help me.
Thanks and regards
Matteo
File format problem
Re: File format problem
You must install Ghostscript AFPL (http://www.ghostscript.com) to be able to read PDF files, see 'FAQ: How to display vector formats? GhostScript!'firemoth02 wrote:I just installed XnView, and I am trying now to convert PDF image to JPG.
.doc can not be read by XnView.I tried also with a .DOC file, getting the same prompt.
